FAQ(Frequently Asked Questions)
Cannot find Wi-Fi signal of Solar-WiFi
1.Make sure inverter is power on and antenna is installed;
2.Move closer to inverter;
3.Restart inverter;
4.Do 'WiFi Reload'operation via button on the front cover of inverter.
Cannot connect to Solar-WiFi
1.Try password '12345678';
2.Restart inverter;
3.Do 'WiFi Reload'operation,and try password '12345678'again.
Cannot login webpage of Solar-WiFi
1.Try admin/admin as username and password;
2.Do'WiFi Reload'operation,and try admin/admin again;
3.Repeat step2 again.
4.Confirm the website is http://10.10.100.253
Cannot find the SSID of Wi-Fi router in site list
1.Move Wi-Fi router closer to inverter or use a Wi-Fi repeater device,restart Wi-Fi in'Management'page;
2.Connect to Wi-Fi router and login the setting webpage to check the channel it uses.Please make sure the channel is not bigger than 13. Otherwise,modify it.
After configuration,the yellow led blinks twice regularly within 1.6 sec.
1.Restart inverter;
2.Connect to Solar-WiFi and login again,check the 'SSID,'Security Mode,'Encryption Type'and 'Pass Phrase'is matching with that of Wi-Fi router or not;
3.Connect to Wi-Fi router and login to check if the connection reaches the maximum amount or not,and to check the channel of it uses.
Please make sure the channel is not bigger than 13. Otherwise,modify it;
4.Restart Wi-Fi router;
5.Move Wi-Fi router closer to inverter or use a Wi-Fi repeater device.
After configuration,the yellow led blinks four times regularly within 1.6 sec.
1.Connect to the Wi-Fi router and visit the portal.Check the portal is available or not;
2.Restart Wi-Fi router and inverter;
After configuration,the yellow led is steady all the time,but the status of PV station on portal is still offine.
Please wait 10 minutes and check the status on the portal again.
Comments
0 comments
Article is closed for comments.
