1- After following the Wi-Fi configuration, if inverter doesn’t connect, please check that the home wifi’s password is correct. Also make sure the password does not contain any special characters
2- Make sure that the RSSI is high enough to connect.
3- Make sure that the network band is 2.4GHz. If it is dual band, make sure band steering is disabled. Also make sure the router settings does not have a limitation to the number of connected devices.
4- If IP address is not working, try using a different device.
5- If light is still blinking twice try to do a W/L Reload and try again.
Comments
0 comments
Article is closed for comments.
