The price per kWh is used to calculate your income from the PV system and is displayed in the SEMS Portal. Usually, the price per kWh is set up during the installment of your system and first connection to the SEMS portal.
Of course, you can always change this price by logging in to www.semsportal.com with your account.
After logging in, go to ‘Management’ >> ‘Plants’ (from the side menu) >> select your plant name. Further down on this page is a field called “Profit Ratio” where you can change your price per kWh and the corresponding currency.
Comments
0 comments
Article is closed for comments.
