* This guide is to help customer register account on new SEMS portal via laptop.
* Customer needs to ensure inverter connected with home router in advance.The amber light will be solid on once wifi connection is successful.
* Customer can refer to the "WiFi connection guide" as well.
TO New Customer:
- link for SEMS: www.semsportal.com
- Tap Register to create account > select End user as system owner.Choose the right location of your area among "AUS/NZ&Oceania、Europe、other"
For example: customer is located in Australia,please choose "AUS/NZ&Oceania",Other means the customer is not located in either AUS/NZ nor the Europe countries.
E-mail will be the account name and password must inc letter and number
- Portal jumps back to login page for log in once registration finish.
- log in on SEMS
Create the power station for system owner:
Tap Settings on top right corner > Tap Plant Setup > Tap Create
- Scroll down page to edit the power station name.
Click the Map for giving the station the correct location.
* Plant Name = The name of your station you want to given.
* Capacity = Total Solar system size.
* Profit Ratio = For example: AUD/Kwh, your feed in tariff. This needs to be confirmed with local installer or utility company.
- Submit station info and jump to Add device (inverter) page automatically by taping Add.
- Add the Inverter Model, Serial Number and Check Code on the page (all info can be found on right side of inverter label).
- Click Submit to complete the registration.
TO Customer who has Goodwe Portal Account before:
- Link for SEMS: www.semsportal.com
- Directly Log in by using the old account name and password.
The SEMS request the E-mail as account name for login.
For customer whose account has not been bundled with E-mail, SEMS reminds customer to bundle with E-mail. Follow the pop out window to bundle with E-mail and log in with the NEW E-mail as account name.
For customer whose account has been bundled with E-mail before, SEMS will remind the bundled E-mail and customer use this E-mail as account name for log in.
Any issue during the registration process, please contact with Goodwe support.
Portal explanation:
Select for more info.
Comments
0 comments
Article is closed for comments.
