1-Connect to solar WIFI of the HomeKit (network name should match the last 8 digits of the homekit’s SN)
You must turn off your mobile data
-Samsung: Go to settings --> Connections --> Data usage --> Mobile data: off
-Oppo/other android: settings --> Mobile network --> Mobile date: off
-iPhone: Settings --> Mobile/Cellular (depends on IOS version) --> Mobile data: off
2- open the browser (safari/chrome)
3- go to "10.10.100.253"
4- login with username "admin" and password "admin"
5- In mode settings, select the working mode to be "STA Mode" and press "submit"
6- go to STA Settings (on the left side)
7- for AP SSID press search (this is where you select your home Wi-Fi) and check then select the network and press "apply" (Make sure the RSSI is higher than 50% to maintain a stable connection, if it's lower, try to get a single band 2.4GHz WIFI booster)
8- scroll down to "Pass phrase" and type in the Wi-Fi password, then press submit
(Please note that if you put the password incorrectly the HomeKit will not connect so make sure it is correct).
9- go to device management and then press restart and wait for the bottom orange light to go solid.
Make sure the network is 2.4GHz, RSSI is above 54% and the network password must be correct.
Comments
0 comments
Article is closed for comments.
